MOV vs COP vs CPS for Studio5000
From a hopefully more reliable Rockwell source...
40596 - Format Conversion Differences Between the COP and MOV Instructions in RSLogix 5000
Access Level: TechConnect
Unfortunately it's TechConnect level but I do hope you can read it, GaryS?
If not, then I would also advocate the "try it for yourself" advice. Even with daba's detailed and accurate corrections and ASF's very precise and concise examples; you may very well not realize that Eureka moment until you witness it for yourself.
Regards,
George
I've used CPS instructions for things like data collection when you need to copy a set of several arrays that are changing frequently (<100ms), but usually, COP is more than fast enough.
Daba and company have outlined the differences between MOV and COP instructions correctly.
I'm having to make an AOI to use with a generic ethernet device because the manufacturer does not provide an AOP. I just want to do a sanity check...
1,265
I have found several places in an old program where COP of length 1 is used on strings, but other places where MOV is used. Is there an different...
4,020
I know this has been brought up before and I have read through many posts and tried many different things before asking... I am using a ML1400 Ser...
5,134
Would someone be so kind as to explain the difference between the cop, mov and cop instructions and where each one may be used? The instruction...
5,944
Can someone tell me the difference between these two instructions and where you would apply one vs the other? Thanks
4,636
