Hi all,
I am programming a Omron PLC.
I need advice on this issue I am having. How do you convert
D100 - &150
to
D101 - #150.
If I used convert the &150 will be #96. How to achieve this? Pls advice. Thanks.
Thanks for the reply. Actually I am doing a floating point multiply for example 10.90 * 100 = 109.0. Then I do a FIX on 109.0 thus getting +109. I want to use this value as a set point for my pulse counter which is in # format. I tried converting &109 to hex which is #69. Thus the count is incorrect. Thinking back is it possible to convert the counter value to floating and do a compare from there. Pls advice. Thanks.
