moxa ethernet I/O or Cellular wireless I/O
diat150
Mar 2006
Louisiana
1,474
Has anyone used the moxa products? I am most interested in the capability to do exception based reporting. basically the device connects to their opc server and reports when there is an upset. this is extremely helpful when you are communicating over cellular or satellite networks. with this capability you can poll just once or twice a day, but still get alarms when you get an upset.
so has anyone used these products and what did you think?
we used to use the wireless access points. really reliable. had the alarm relay outputs and everything. din mountable and durable. there are awesome prices on them if you look around. see one on ebay for $149 now and another for $350 or so.
Hello. I'm considering using DIN rail mounted, managed Gigabit Ethernet switches from Moxa...
20
4,946
I'm trying to get comms to a SLC CPU 504 using a moxa gateway EIP 3270. I can use their Procom software which sets up a virtual comm port so...
5,323
How do I connect 5 PLC's (RS232, DB-15 connections) to 1 PC (1 EtherNet port, 1-RS232 DB-9 port)?? I know we need to use a MOXA, but how does a...
2,572
Hi All, I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems...
818
We've been using Allen-Bradley's 1783-NATR and find it is easy enough to work with. Unfortunately, it only allows 5 ports to be opened per IP...
780
