MP277 Data Logging
erdemsvri
Jul 2009
Germany
172
Hello
I want to record data to a storage card with WinCC Flexible 2007. I have found the script in plctalk but I am so new in scripting that I got confused I have some question I will be very happy if you can answer
I am wanted to record data when machine is working in CSV format and on the HMI panel there is a IO state where the operator writes the frequency of the data logging like 15 minutes or something like that.
The MP277 should record date, time and preset value every 15 minutes for 5 seconds with the maximum frequency (5 seconds is constant). I mean the more data logged the better they say like 5000000 data each 5 seconds (I know 5 million is impossible but I write that to emphasize what I say) HMI shouldnt record when the machine is not working...There is a button on MP277 which deletes all the records and if data is not deleted before the card is full a warning message should appear and data should be logged on to the oldest log...
- I think of making a internal tag for machine start and stop which starts and stops logging (probem with emergency stop here!) this internal tag should record data and start a timer of 15 mins and after 15 mins the same process but I dont know if the HMI can do other job when the script is runing I mean could the script run background and HMI acts normally like there is noting going on?
- Can I use my external tags to call the script? What are the ways of calling a script? I mean can ı do something like that on HMI if a > 10 call script or if a == 1 call script (a is a external or internal tag)
Like I will put the timer to PLC and make a tag of it and use this tag to call the script which will record data to the card.
Is this possible?
I m stuck here I dont have the basic knowladge of scripting.
If I can figure how to call the script and stuff I will use the code in plctalk...Could somebody tell me how and why are they used basicly?
Thanks very much.
Hi All I am trying to get a consistent historical trend length for all my MP277. I have several MP277 in use with similar settings 5 -10 data...
1,018
Hello Friends ! Using siemens wincc flex and lgging the historical data on MP277. Need to view all the data on remote PC which is on ethernet. How...
4,899
Hi Iam using MP277 10" I will be connecting it to PLC through profibus. Also it can be connected to a PC through ethernet port. Now is it possible...
2,262
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
173
Hi All, I currently have an damaged MP277-8" Touch panel (6AV6 643-OCB01-1AX1) which I am able to backup (.psb) via ProSave. We are in the...
2,871
