MPK 800 for elevator control
fery
Jun 2009
batam
I am still new on this MPK 800 elevator control, I want to ask about PE terminal on MPK 800 is it need to connect to the ground?? and if negtaive from DC power supply connect also connect to ground,because ground also using for welding equipment is it can make PLC MPK 800 spoilt?? anybody have idea on this??
thank you
regards,
fery
PE is - PROTECTIVE EARTH
earthing the -ve terminal is your choice -
Welding earth should be direct to your welder and as close the the device being welded as possible.
the current is too great to allow it to travel through your control wiring. Using the Machine frame is dependant on propper bonding.
Any problem with bonding will cause the weld current to travel through your control wiring and probably cook it.
Dear all, any body can help me to solve my problem, i am repairing 2 lift control they using MPK 800 and FKP for car control. The problem is MPK...
3,767
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
41
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
51
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
131
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
237
