MR-J3 movement greater than 360 degrees
macgioo2
Oct 2009
Cambridge
98
Hi Guys,
I'm using a mitsi..mrj3 servo in a wind application and I would like to be able to specify an absolute rotation amount greater than 360...for example 450 degrees which I could specify....i know there are other ways of doing this...but is possible to feed in 450 in some command line and get one and a quarter turns?
Any help would be great thanks.
this depends on the resolution of the servo motor encoder.
I am thinking the standard is 2000 pulses per rev. (if it is not a resolver)
so you can configure this as you wish.
My only concern is if you are using this for a wind situaion how do you avoid going past 450?
Hi Ian,
Yes it is standard configuration set up in degrees. It can be set up as I wish.
Are you suggesting that I revert back to controlling position using pulse counts?
I was hoping there existed a command which allowed this 420 degree turn, the servo would stop by the nature of the operation and I could create a flag to confirm the position based on the start position + 420.....eg 180+420=600=240
Possible?
Oddly enough I dont do a lot of Servo programming.
I am fairly certain that you can configure the rotation to 720 (0.5) accuracey.
then do as you suggest but reset the start position at 0 degrees so you maintain the accuracey
hope that helps
3,852
Hello Everyone, i have a machine that picks up a bottle and moves it to a position. There are six positions it needs to move to before going back...
2,132
We have a tissue Embosser which uses AB Kinetix 7000 drives and HPK servo motors. This particular fault concerns a 2099-BM07-S drive controlling a...
2,558
2,627
i'm looking for drive or drives that should" run vertical and horizontal conveyors, both should sync, able to run in different speed, thanks...
2,378
