msg to a pc or fanuc robot
phinix
May 2006
l.a
33
hi,
1 . i saw a few threads that talked about msg from a ab plc to a
pc via ethernet ,i whuld like to know how do i set the msg in
rslogix5000 to do so , and what type of tags can i transfer ??
2 . if 1 is posible is it posible to do the same thing to a fanuc
robot with bilt in ethernet ??
3 . thanks !!!
There are a lot of ways to get data to a pc, but I've never seen a message instruction used. I'm not aware of any way that would work.
It is posible to message to a fanuc robot. Having said that, I've not done it yet. There should be documentation on the fanuc web site.
122
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
210
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
201
I'm trying to read/write to an SLC5 with a ControlLogix L71 V35 plc that fails. The exact same code works on an L82S with V32. Is there a known...
311
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
385
