Mts absolute encoder and contrologix 5000
acm
Dec 2008
México city
I am working with an absolute mts encoder through ethernet connection, connected to a contrologix 5000, but after a few instances the reading is fixed and no longer answer it is necessary to reset the encoder to send the position again. However after some instants it is returned to freezing. The encoder is a rp5ga0040u01d581u201, the processor is a l73 with firmware 28. I hope that someone can guide me about it
I've been tasked with adding a 3-wire pressure differential transmitter to a system and drawing up the wiring to an existing PLC board. The...
792
I have 2 different MTS Temposonics R-Series position sensors being used in a program. Each MTS is tracking a single axis on separate machines...
2,766
Dearest Colleagues, Task is to communicate on two levels. First level is to collect data in PLC from some flow meters and handle them, and second...
2,135
Mts
I have a temposonics transducer where the Red LED is flashing. Missing (external) interrogation Do you know what that means?
2,927
