Multi Speed Servo Jog CLX
johnfarrugi
Mar 2008
London
99
I have an application that allows an operator to jog a servo forward or reverse, slow or fast speed with push buttons. As I understand the MAJ functions in CLX, they are triggered by a state change and motion needs to be stopped by a MAS command. Is it posible to change jog speeds without stoping the axis? I want the operator to be able to hold in the forward button and press the slow/fast button to change the servo speed without stoping the axis.
I am using a compact logix with a sercos card.
I think I figured it out. I believe once a MAJ command is initiated it continues until either another MAJ command it initiated or until a MAS command is recieved. Therefore, to change the velocity of a jog axis, I just need to transition a MAJ command with the new velocity.
Am I correct?
Am I correct?
Yes.
If you use a tag for the velocity parameter in the MAJ, then by changing the value of that tag and re-triggering the MAJ, the axis will change speed. Probably a good idea to enable the merge option.
(you don't need two MAJ instructions)
Hi
You could also use the MCD motion instruction.
Your way will work also but as I find its always good to use a new instruction and learn something new.
Talk again
Donnchadh K
I will probably NOT be starting a machine up on site. So I am trying to make my code where the start up guy can read and hopefully understand it...
2,703
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
298
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
144
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
568
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
523
