Multi turn Gray to binary---Help
pauly
May 2002
South Wales,U.k
244
Ok I've posted about a single turn Gray absolute encoder and conversion to boolean and had great help. What about a multi turn encoder, how do you convert that? Do the turns bits need to be converted seperately or would the 24 bits be converted as a whole word? I'm getting desperate now!!!
Don't panic, Don't make it harder than it really is.
The same way only there are more bits.
Now think about it. Why would the turns be different from the angle? Then there would be places were two bits would have to change at the transition from one turn to another and that would defeat the purpose of the Gray code where only one bit should change at a time.
I may have something coming up that uses a multi turn absolute gray code to binary, parallel interface encoder. I do know how to convert the...
18
11,468
Hello dear experts! I am new in controlling tasks. I need to regulate an oxygen flow rate on the compressor outlet by AUMA SAR 10.2 multi-turn...
1,700
According to LED light on my 842D DeviceNet Absolute Multi‐Turn Magnetic Encoder, the encoder is"Active but not allocated by master devicenet"...
1,899
I am using a Rockwell 842d absolute multiturn encoder with a 1747 SDN Devicenet scanner. Where the encoder is a 26 bit encoder I was expecting to...
2,197
Hello everyone, I wanted to change/reset the position value of the above encoder. I have RSNetWorx for DeviceNet and RSLogix5000. What is the...
2,324
