Multi-zone Safety system ?
milmat1
Aug 2005
North Carolina
209
Hi All,
I am not experienced with multizone safety systems at all. And I need to design a system for a machine that has at least two separate zones.
Zone 1: Will have Estop button, two light curtains and some pull cord switches. Any of which Will Estop the entire machine as normal. Removing control voltage via a safety relay and pulling an STO (Safe Torque Off) Signal from the VFD's.. Just a normal emergency stop circuit....
Zone 2 however will be much different:
1, Operator enters zone 2 and triggers light curtain. At this point nothing happens until the overhead gantry needs to move into the area of zone 2 where the operator is. If operator is still in that area I will stop the entire machine as a normal estop.
However if operator exits the area and hits a local reset button before gantry is ready to move then machine will continue running..
Machine control is using a Control Logix PLC / VFD over Enet
What are the options here? I am considering using an ASI network (AS Interface) due to its programmability.
I work on a plastic extruder that uses the following components: SLC 5/05 PLC Eurotherm T940 Process Supervisor -Eurotherm 2500 modules...
1,601
Hello, I had a question about benchmarking the Rockwell FactoryTalk View SE software. I've installed in the neighborhood of 30 different...
283
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
136
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
545
Hi Guys, I'm trying to integrate Pilz Ethernet IP Module to ControlLogix. I added Pilz module as a Generic Ethernet module and I'm able to...
513
