multiple 1785-enet
MajorFault
Nov 2007
Louisiana
36
Can you run multiple 1785-ENET cards in a plc 5/40e?
I would like to have one for a scada system connection, and another to a pc based system that will give the PLC target setpoints for a motion system. That's two subnets.
Is that possible?
The 1785-ENET connects to the CPU using a 50-pin card-edge connector, rather than the 1771 backplane.
You cannot connect more than one to a PLC-5 controller.
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
46
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
121
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
67
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
182
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
528
