Multiple I/O Configs in Allen-Bradley ML1400
madisjc
Nov 2010
Texas
I need to create a frankenstein machine that has an additional expansion IO card, compared to the normal configuration of our machines.
I don't want to have to create a new branch of code just because of this, since I'll have to update ever new feature in two separate programs then. Is there any good way to handle this?
Do I have to write some VBA script to swap back and forth between different numbers of expansion modules?!
Thanks,
John
Yes, you do.
madisjc said:
...since I'll have to update ever new feature in two separate programs then. Is there any good way to handle this?
Thanks,
John
Keeping two versions would be the simpler choice in my experience. It would be different with CompactLogix, I think as far as feasibility but, I would still just have the different configurations as differently named and saved Logix files..
It is possible to turn off the bit that tells the controller to check for a configuration error. This is useful for testing without matching hardware, but if left off once commissioned, it can lead to problems when there really is an error and it gets ignored. It might be possible to script RSLogix500 Pro to check those bits as appropriate before you download...now if one slot has two alternate configurations I think you are screwed unless you could in a fault trap write the module ID to the right spot...this is way beyond too much trouble for this Okie. I just SaveAs RevB_v001...and fill in the paragraph in the revision notes window..."This version is for machines with 3 expansion modules to accomodate the following blah blah blah...".
Well from one okie to OkiePC, thanks for the reply. Not the answer that I had hoped for, but it is what I expected.
Thanks.
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
120
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
64
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
180
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
527
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
327
