Multiple Workstations
prg
Apr 2003
Hi guys! is it possible to run RSlinx on two different pc's simultaneously without having them hang up? Even if two people try to access the same controller at the same time using RSWho?
Yes
We have two PC's running RSLinx & RSLogix, so we can access the DH+ network from 2 locations within the plant.
I have try it, one PC was connected via ethernet and other was in RS232C connected to RSLogix5000.
When one or the other makes changes to PLC program that other can see it with small icon on the right bottom of the display and RSLogix tells program has changed, please save it.
Variable tables could be done misstakes if one or the other changes or makes newones.
If both looks same Rung, both can see if other are doing changes.
Yes, you can access one controller from two PC's.
But only one can do online edits.
I believe it is simply the first one that starts editing that locks the other out from doing any edits. But, the other PC can still look at the controller.
With CtrlLogix5000 it works well, we ware 2 people doing FAT and we made edits etc. But varable-name changes must update separetly, so be carefully with them. Maybe there is the better way for handling variable names.
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
94
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
43
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
161
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
518
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
321
