mx sheet with Allen Bradley
a11anjones
May 2009
oswestry
17
Hello everyone,
I have recently been trying to learn about Mx sheet on excell. This software primarily is designed to work on mitsubishi controllers. Although I have read that it can work 3rd party plc controllers via a GOT ( HMI ) . Does anyone know if it possible to run mx sheet with an Allen Bradley controller via an E700 mitsubishi HMI on ethernet.And if so how? đź“š
Regards , Allan.
Not sure about MX Sheet but you can set the E series HMI to two different protocols i.e. 232/422 to the AB plc then set the Ethernet to say mitsubishi & pass data from one to the other.
This is done using Functions\Data xchange.
You set up triggers (plc bits or time based) from one controller to the other i.e. N7:0 to D100 at 1 second rate.
The trouble is that MX component expects the controller it's talking to to be a real plc where the data from the AB to mitsi is data being sent to controller i.e. mx expects to be master requesting data but the data exchange is the master trying to pass to a mitsi plc.
not sure if this will work. as there is no protocol for MX Sheet
Hi, I'm curious if anyone has made a master sheet or cheat sheet for all allen bradley card's analog inputs/outputs? As much fun as it is to...
1,603
Hello, My background is IT, and I have very little (effectively zero) understanding of PLCs. I have been tasked with acquiring version 2 of...
113
Hey guys how would you approach the spreadsheet screen part? I searched and everyone points out that using parameters to display this information...
761
Is it possible to pull information from a specific cell in an excel spreadsheet and use it in a program? I am wanting to display a time amount for...
1,174
does anyone know how or If you can Change the default sheet size to A3 for New FBD's so that when you create a new FBD during online editing it...
769
