Naming bits of a word in Siemens
manmeetvirdi
Oct 2004
India.
750
Hi there
I have a data block (using Simatic Manager V5.3+SP3)
In this I gave the name of dbw0 as alpha
Now inside the program Iam using the various bits of this first word (alpha)
Ex dbx0.7,dbx0.6 etc
I want to name these individual bits too !
Is it possible?
You can create an ARRAY of bits in the data block, give the array any name you want then adress them like this;
A "test".bit[1]
A "test".bit[3]
A "test".bit[2]
(my db is named "test" and my bits named "bit")
All the bits in the ARRAY have the same name but a [number] to identify them.
Maybe this will do you?
Hi, In our company (programming mainly Beckhoff PLCs) we are establishing internal coding guidelines for ST. Until now, the conventions were...
1,116
I have a question about process interlock naming. I want to hear opinions, as well as if there is a relevant standard. When naming specific...
677
I'm from a Mitsubishi Q-series background so excuse my ignorance. In Mitsubishi world, in my experience your Mbits (booleans) are just M1, M2...
20
2,827
I am interested in good examples and best practices when choosing a project file name. Would you expect to include all or some of the following...
2,291
I have a small modification that I want to make to a program in an S7-1500 using TIA portal V14 SP1. I have a global data block containing some...
3,793
