Need 1761-CBL-HM02 pinout
blmccallum
Sep 2007
Alabama
Does anyone know the pinout for the AB 1761-CBL-HM02 cable? I've been looking for it on the AB website but can't find it. I am trying to make my own cable to connect a MicroLogix 1000 to a 1761-NET-ENI module.
Thanks.
RA Knowledgebase document # 18942 includes the pinouts for the 1761-CBL-AM00, -HM02, and -PM02 cables.
"A" suggests Accessory
"H" suggests Handheld Programmer
"P" suggests Personal Computer
These were the original purposes of those cables.
As you know, the MicroLogix 1000 has +24VDC on Pin 1. Take care with that connection to avoid letting the smoke out of the devices you connect to.
Also; don't try to force a PS2 connector to fit this plug. Old AppleTalk cables are the best surplus source for a compatible plug, and there are a handful of other sources.
Remind me to tell you sometime about the 8 days a customer of mine spent in the Arizona desert in 110F heat, and the two new PLC-5 controllers he had airshipped to him that he insisted arrived defective. His homemade 1784-CP10 substitute cable had broken the Pin 2 wire inside the shell.
Yes, but the "Adventures of Ken's Automation Project" stories are always great! I still want to hear more about the golf course
I have a 1761-net-eni. I need fixed-format Web-server functionality just like the 1761-net-eniW. Is there a better solution than buying another...
1,602
Can anyone help place a message in a string data file so that it can be sent via email to the desired location.Any code using RSLogix 500 will be...
2,297
i connected the device to a 1500 PLC, and it is working fine ( i can load and download programs to and from the PLC using RSlogix ), problem...
47
9,440
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
107
70
