Need an Excel guru's help converting ASCII to Decimal
wildswing
May 2005
Sault Ste Marie, Ontario
281
Do any of you Excel gurus know of a VB code or function that will convert ASCII text into it's decimal equivalent? I'm not VB savy at all.
I need something that will do this...
A ---> 65
B ---> 66
C ---> 67
What I'm eventually trying to achieve is a spreadsheet in which I enter ASCII text string and have it return the equivalent decimal values like this...
Text entered (thinking one character per cell - 20 characters max)...
3/8 X 8 SUP
Returned decimal equivalents would be...
51 47 56 32 88 32 56 32 83 85 80
I can take it from there, converting to binary, combining into 16 bit integers for use in selecting recipes in an oem apps database.
Any advice or assistance you can provide would be very much appreciated. Thanks in advance!
I searched and maybe this will get you going.
=CODE(A1)
Type this into a cell and then place your ASCII value in cell A1.
Time for yard work.
Hi... I m working with delta PLC. I can interfacing between Delta Software and Intouch Sw. Now I have to export the data(sensors values) of delta...
3,349
I need help with trying to expand a program that takes pressure and position from a ram follower machine and puts it into excel. The excel sheet...
34
6,163
Hello, I had a previous post regarding Excel and RSlinx not updating automatically. I am running Excel 2007 and Linx Classic on my PC. I have...
6,067
50
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
281
