Need Ethernet/IP analog out module for CompactLogix PLC.
eddiemaxie
Apr 2020
Wisconsin
Hello Everyone,
A very important question:
We are having trouble receiving analog output cards (5069-OF4) for our CompactLogix PLC racks.
I am looking for a 1 channel 0-10VDC remote analog output device that my Compact Logic PLCs can talk to using Ethernet/IP. Can any of you suggest something?
I need at least 1 analog out channel. If the device supports more, that is OK.
I am currently looking but have not found anything. You would be a hero if you can help me identify something!
Thanks,
RZ
We've used Click PLCs as Ethernet I/O when we could not get enough Rockwell analog modules for a project. Clicks with Ethernet support Ethernet IP Adapter Mode and the (free) Click Programming Software will create an EDS file for you.
I haven't tried them yet, but I saw an ad for Acromag products that claim to work that way. If we hadn't been able to get our hands on these 1769-L24ER processors with on board analog inputs, I would have had to scrounge for sure.
https://www.acromag.com/product-cat...-i-o/ethernet-io-modules/ethernet-analog-i-o/
They come into the IO tree as a generic ethernet module:
https://www.acromag.com/wp-content/uploads/2019/08/Compact_Logix_AppNote_8500762.pdf
Last I checked, the analog input modules for Point IO were showing crazy lead times too. Haven't checked Flex IO lately...
I like the idea of the Click PLC as I/O too. I might have to look into that at some point.
Hello Everyone,
Thanks,
RZ
geniusintraining has some stuff in stock for point I/O.
https://www.plccable.com/allen-bradley-1734-oe2v-point-i-o-analogoutput-module-volt/
Hello Everyone,
Thanks,
RZ
Turck TBEN... TBEN-S2-4AO
I am replacing a non functioning e.w.o.n cosy 141 that is converting serial communications of a compact logix to ethernet. Any recommendations on...
6,316
Anyone know of USA built or assembled un-managed industrial Ethernet switch. 4, 5 and or 8 port configurations? Thanks,
1,600
Hi, There is a 1756-L61 connect the FLEX I/O 1794-ACN15 by Controlnet coaxial cable. The question is could I just replace the 1794-ACN15 to...
6,377
Hello! I have the following items: CompactLogix 1769-L16ER-BB1B Processor PowerFlex 753-NET-E-AC Drive via 20-COMM-E drive. I noticed that...
7,462
We have a runtime file for a Panelview that's set up for DF1 communication protocol. We want to change it to communicate with the same PLC...
3,413
