Need help about Drive selection
Please excuse my bit of fun
I need batteries for my crystal ball.
most Drive manufacturers will be willing to help you.
you need to know HP/KW - load / friction what are you doing.
other than that it is guess work from us
As already said, we need more details.
Application - is this a HVAC application, a conveyor orsomething else? Many manufacturers of drives are building custom drives for different applications.
Motor data - including nominal motor current.
Environment.
Once you have all that I could recomend you to look at Danfoss's configurator:
http://drivecat.danfoss.net/ipc_stdalo/init.do?scenario.xcm=z-dd-ipc_stdalo-sec
Best regards,
Michal_dk
Absent any specific data, the general process is this:
First, understand the torque-speed requirements of your load
Second, pick a motor that will produce those torques over the speed range and select a voltage and enclosure that meets your local needs
Third, find the motors current requirements to produce the torque over the whole speed range. There are two torques and resultant currents---continuous running torque and short-term peak torque. These will give you continuous running amps and peak amps
Fourth, select a drive with continuous and peak current adequate for the needs of the motor. Also, determine the drive enclosure type and I/O requirements including fieldbus communications, if any.
That should do it. Notice that hp didn't play any part in the process.
Hi All , I have a Fanuc Robot System(R-30iA) with a drive ( FANUC A05B-2500-C001 ) , and I need to Know how to upload \ Download a backup from\...
3,251
hello guys... I have done communication with omron cp1l plc and yasakawa v1000 ac drive now I'm able to write drive parameter from plc program...
3,083
This is an older system. My supervisor managed to let the magic smoke out of two of the comm boards in the ServoDrive controller, after replacing...
1,339
Dear Friends, We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at...
3,895
Hi Guys, I want to use OMRON Servo Drive OMNUC G, R88D-GT type for speed control applications, whether it can output an analog of the PLC OMRON...
2,193
