need help in twido urgent
elhagan
Sep 2003
cairo
48
hello friends
this is the first time to start program with twido plc
and hitech screen pws 6300 s i use twido soft v 3.2 and ADP V 6 for the hitech screen i make all the plc program but i cant make the momery words in twido
example
i have 7 timers i need to read and write the timers from the screen
in siemns i use move block like this >>>
and i can read the word from the screen alarms like this also in siemns >>>
now i want to make like this in twido i have 8 timers and 8 counters and 4 alarms
i need to read and write from the screen
the project file in the attachment
i wanna know how to make register move from the plc to the screen
i need examples
any help
elhagan
Wow. I have not used a screen I have had to drive for over 12 months. Just about all screens do their own interrogation of the PLC these days. Much easier.
nothing to say lol :sick:
Twido alarm
The logic you need isn't all that different than the Siemens logic. I don't want to sound like one of those Linux guys whose response to any question is "read the manual", but...
That being said, here's what you need to know:
Memory is %Mx for bits (like %M3) and %MWx for words (like %MW3). These don't overlap. You can refer to the bits in the word as: %MW3.0 - this is NOT the same as %M3.
Timers use a %TMx, like %TM3 . The preset (setpoint) is in %TM3.P, and the accumulated value is in %TM3.V . If the timer is marked as writable the setpoint can be assigned from another memory word with something like %TM3.P := %MW3 .
Your move would use an operate box with this inside of it: %MW50 := 10
Good luck!
One other quick question - what protocol is your screen using. If it's using the Tele protocol you should be able to directly access the %M and %MW areas, but nothing else. If it's using Modbus then the %M's turn into 0XXXX, and the %MW's turn into 4XXXX addresses, with %M0 = 00001, %M9 = 00010, %MW0 = 40001 and %MW9 = 40010.
solution
In modicon make PLC for writing & reading the of timer value in PLC we use this format:for writing the value in timer %TMX.P:=%MWY
X- is the timer addres/no. and Y- is the memory word address.
for reading the value from timer %MWZ:=%TM X.V
Z- is the address of memory word and X- is the timer addres/no.
Good luck!
special thanks to you your very great man thanks again i make the program and i read the manual before i read your replay. look to what i understand from your replay
example >>>
%TM0.V (V) READ FROM THE TIMER
%TM0.P (P) PRESET VALUE TO THE TIMER
AND %C0.V & P THE SAME THING
IF WE WANT TO READ AND SET FROM THE SCREEN WE MUST MAKE OPRETOR BLOCK AND SAY %MWx:=%Cx.V or P
like this >>>
to know its good >>>>> continue
thanks again
i have problem with the twido and the screen in The illustration of the connection i send 2 mail to the scrren factory and very bad factory he cant find way to conect this screen with twido if you can find way to me i will be glade to you
i cant understand this replay can you explain
i think twido is modbus or tru
thank you altaf
i understand your replay
now i have another some thing in the alarm table i wish all help
i have 3 alarm input
1- %I0.0 EMG
2- %I0.1 SPEED DRIVE ALARM
3- %I0.2 MOTOR LEVEL ALARM
I WANT TO READ ALL THE ALARMS FROM THE SCREEN
I TRY TO MAKE OPRETOR BLOCK LIKE THIS %MW200:=%I0.0
HE DIDNT ECCEPT IT
I NEED TO USE THE ALARMS IN SCREEN HOW TO MAKE MEMORY WORD FOR ONE INPUT
LOOK TO THIS SCRREN FROM THE HMI PROGRAM ITS THE ALARM TABLE
you see i have 1 %MW I MUST USE ALL THE 3 ALARMS UNDER THIS MEMORY WORD WHAT I DO IF I MAKE OPRETOR BLOCK LIKE THIS HE DIDNT ECCEPT %MW200.1:=%I0.0
%MW200.2:=%10.1
HE DIDNT ECCEPT
WHAT I DO TO MOVE THE INPUT TO %MW
BEST REGARD
ELHAGAN
a word (%mw) is 16 bits, and %I0.0 is just one bit, so you cant mix them.
but you can move one bit into a word, one at a time.
%MW0X0:=%I0.0
puts value of your input into first bit-position in your word.
/Mats
To work with consecutive memory words the format is: %MWxx:yy, where xx is the starting memory word and yy is the total number of words desired.
In your situation the syntax for grouping the 4 alarm words would be %MW200:4.
hi every one how are you . i have this question maybe it is silly but i have no one to help me. i have twido plc and i need to send and recieve...
1,755
Hi evrebody! I am new here and in PLC programming. Need help with PLC TWIDO. How should looks ladder in order to do next: 1.In the end of program...
1,667
194
175
134
