Need help reading 1395 Drive data on DH+
colemanj2000
Dec 2006
Alabama
I have an AB 1395 DC Drive with a Multi-Comm board, it shows up on the DH+ in RSview and I can read it's data using Drive Manager. But I can't get it to read into my PanelView 1000 Plus or into an Excel spreadsheet via DDE link to RSview.
I've read that the drive emulates a PLC-5 and maps it's parameters 0 thru 999 to N10:0 thru N10:999 so in my
RSlinx DDE topic I choose PLC5 and in my spreadsheet I look at
N10:633 (parameter 633) but it doesn't read data.
Also I set my Panelview to look at it's DH+ address as a PLC5 but it doesn't read data from the drive either.
Certainly I don't have to transfer the data into another PLC and read it from there do I?. Is anyone able to read this drive data on a Panelview or into a spreadsheet ? Thanks.
My DDE syntax
In an Excel spreadsheet cell I have :
=RSlinx|1395DRIVE!'N10:633'
This is to read drive parameter 633
This syntax works when I try to read from an actual PLC5.
I have a Topic in RSlinx named 1395DRIVE, it is setup as
PLC5 type.
I can’t able to get data from IN16I analog card, signal type 4-20 ma System configuration Rack 1 Slot-0, L551 CPU Slot-1, BSN Rack 2...
2,087
Need assitance converting .RSS file for a AB SLC Processor to Adobe format. Any assistance would be appreciated. Thank you.
2,146
I have an AB 1500 LSP and I need to maintain a steady pressure of 80psi +- 10% from an analog 4-20ma pressure tansducer. I also have a 4-20ma...
19
5,674
194
175
