Need help with a question in PLC homework
msk
Sep 2017
denmark
So ive chosen the first option. Is it correct? it would be helpful If i could get an explanation too. thanks
obviously SK has better eye sight than l,
otherwise l could possible answer.
if it was me, l would look at ; posted/preview and then go post
But this is kinda vague and depends on what is meant by 30s after startup. The steps in SFC also have prebuilt-in timers you can use to transition after a preset time
1. so do you want it to hold in step_001 for 30seconds no matter what.
2. or is step_001 the startup routine and you want it held for 30s after it has finished it's execution.
3. or You want it held after the start transistion for 30s before Step_001 executes.
for condition 1
from a quick glance the first rung is correct, the step_001.x bit will be true for the duration of step_001 being active, so as you as you transition into step_001 the timer will start, however if you process takes longer than 30s it will exit prematurely. rung 2 is no good because the 5000 series timer Presets are always in ms so it would only run for 30ms.
for condition 2 you would need
to change the XIC to look at step_001.DN bit which would trigger the timer to start when the step finished it's code execution. and time for 30s
For condition 3:
you would need to trigger the timer on the Start bit and have transition_000 be Timer_step_001.DN
I have a few PLC questions that are on my test and there are bonus questions but I would like To get some help on answering them because I would...
3,117
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,260
Hi all, Thank you for viewing my post. I'm modifying a system and added logic to it with the RsLogix 5K. I'm doing CIP routines and have my...
2,296
What is the maximum integer unit for analog input of siemens 300 plc? pls help thank u in advance.
3,959
ok I have a noob question that I am sure someone on here will shoot out an answer in 1 second and make me feel stupid. I have a 3 pos switch the...
2,213
