need help with FX0S please
paul curren
Nov 2006
dublin
can a string of binary numbers be set up in a data register on a FX0S plc to track the flow of different sizes boxs on a conveyor. and will the register be update without over writing value already stored. can anyone tell me the steps needed and comands to use
thank you paul
Never worked with that plc but if the programming supports Bit SHift Left or Right registers, I would think you could set up a different register for each size box, and shift the bits with a trigger. Each time a box is placed on the conveyor, move a "1" to the register and with each cycle of the trigger it will be tracked thru the process as the "1" gets shifted thru its word (left or right)
Need help to control Hitachi L100 frequency invertor with PLC Mitsubishi FX0s series. Is it possible to connect them somehow?
8,523
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
118
78
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
394
202
