Need help with some easy code
bobwithdana
Dec 2003
california
239
PLC5 What is the easiest most effencient way to program a panelview momentary pushbutton to latch a bit when pressed and unlatch same bit when pressed again. I have seen this done with one shots and latches and also with counters etc. Want it clean and simple
Thanks in advance
Bob
Why not latch it in the PV?
The above reply is on the right track, but I would use the maintained type...
Press once, it energizes.
Press again, it de-energizes.
it could also depend on what is button used for, does it need to maintain it's state during power down, what resources are available (latched button also requires handshake bit), what user (programmer) friendliness you want to achive. maybe you are logging what button is pressed and when so you don't like maintained or latched buttons, maybe you want for simplicity to keep all buttons momentary regardless if on HMI or not and assign them functionality you need by program etc. it all depends...
http://www.plctalk.net/qanda/showthread.php?t=22162
I bought a moller easy 512 plc, in hopes of using it to be able to automate 3 pumps. Problem is how do I "program" this plc to do what I want...
8,470
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
101
67
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
376
194
