Need Help with SSUM
The Plc Kid
Feb 2009
Macon, Georgia
3,233
I need some help with the SSUM instruction for logix.
This instruction has IN1 and IN2 being used as well as Select1 and select 1 and out.
The enable bit is 1 and is just placed inthe instruction not a tag so it is on all the time. In 1 is line speed and In2 is slack takeup speed. Select 1 is 1 and is placed in the instruction and not by a tag. Select 2 is a bool tag from a pushutton 1 or 0.
My understanding of the instruction help is that if select 1 and 2 are both off i will have no output correct. Well select 1 is always on which is line speed when i hold the pb and select 2 is high does it add/ sum slack tke up speed value and line speed and just outputs line speed when the PB is low 0?
Is my understanding correct.
The instruction help is a little vague.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
104
67
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
377
194
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
94
