labingtone
PB1 and PB2 are part of the manual mode (start/stop control), and 2posSS and LevelWS to control the MCR in automode.
2posSS is used to bypass the Manual Mode.
when the control is running in automode 2posSS(2 position Selector switch) is ON and PB1 and PB2 will not be used
Condition 1(Normal operation)
-when LevelSW is ON then MCR will ON. when LevelSW is OFF then MCR will OFF
Condition 2
When LevelSS and 2posSS(2 position selector switch is turn OFF very pass) is OFF at the sametime.
-MCR will is still ON
What is the best solution without rewiring the system in order that condition2 will not occur?
can I add resistor in shunt with 2posSS to absorb the energy in order not to turn MCR?
best regards,
Lovington Dela Crur
Condition 2
best regards,
Lovington Dela Crur
