Need Ideas
StuCazzo
Nov 2003
Windsor
Well we are doing our TR, and we have a S7-300 and a TP-27 HMI, we would like to be able to control a motor, and have the HMI display Speed and be able to speed up / slow down the motor, what other supply / parts would we need?
Again it depends on the DRIVE (doesnt really matter whether its AC or DC) but does matter if it has communication capabilities such as Profibus, Modbus, Devicenet, serial etc.
Just about all drives can use an analog input like a potentiometer, a plc can send signals similar to a potentiometer to vary speed using analog outputs from the plc to an analog input on the drive. You would also probably need a High Speed Counter to read feedback from the motor to "know" speed.
This method is not as eloquent as the communication options but its a tried and true method that is usually fairly simple to implement. In many cases the communication addon for 1 drive is much higher than an analog card for the plc. With multiple drives the communication card addon could prove more useful.
Overall I agree with Dark Knight, if the drive and plc is capable of using Profibus (or any communication method) then that would be the best route.
Hi all. I am writing a program in RS Logix 5000. I have 8 pieces of support equipment that are exactly the same. They supply high pressure water...
1,768
hi! Background on me: Self learned programmer mostly on LOGO, s7-1200, regular HMIs and WinCC Flexible 2008 Runtime. Only smaller projects. The...
20
4,194
Need some ideas as to how to do a "for each" loop to check what box is measured. Hello, I need some help in understanding the appropriate...
3,953
I have an application where we have a truck loading program written in Visual Basic. The truck loading program issues a permissive to a Reliance...
1,789
Hey fellas, I'm looking for ideas. I've been asked to look into creating a system that will measure the length of panels cut by our flying cut...
6,933
