Need information for Protocol Asi
smile
Mar 2004
bkk
36
I want to know protocol of ASi bus.
Anyone have this information please hint to me, i want to control actuator via ASi bus by PIC18F458.
From http://ourworld.cs.com/rahulsebos/Links.htm
quote:
Also known as: AS-i, AS-Interface, EN 50295, IEC 62026/2, Sinec S1, SiriusNet AS-International Association
Sites
http://www.as-interface.net
http://www.as-i-safety.net
http://www.as-interface.com
http://www.siemens.de/siriusnet
http://www.bihl-wiedemann.de/press/articles/powext_e.htm
http://www.infoside.de/infida/asi/asi000.htm
Literature
Madelung, "ASI: Das Aktuator-Sensor Interface für die Automation, 2nd Ed.". Hanser Verlag 1999. ISBN 3-446-21065-2 (English version) ISBN 3-446-21064-4 (German version)
Note: an update to this book for AS-Interface version 2.11 is available as PDF from the AS-Interface Association website!
As far as I know, ASi is not based on one of the "common" electrical standards known as RS232, RS422 or RS485. It is a special (but openly defined) standard.
This means that you will find it difficult to create your own ASi communication device, as you have to figure out how to make your own ASi hardware. Consider an ASi "kit" for smallvolume vendors. That could save you a lot of trouble at a reasonable price.
Example of ASi OEM kit.
I need to communicate siemens S7-300(CPU 313C) to a mitsubishi HMI that supports MPI. I have search a lot on net but couldnt find information...
3,687
Hi i have just been asked to upload a plc program from 1511-1 pn it has v15 firmware 2.6 the machine oem doesnt support the machine i got...
2,637
I am communicating with AB PLC through Ether net and able to read the N words. Want to read B as words but not able to read them as words. Has to...
1,928
I need help to install PCS-7 ES/OS Ghost copy on new and upgraded Simatic PC . While trying to load ghost on new Simatic PC , but Pc could not...
1,907
hello, i need information on PLCs & there HMIs. Actually, i am working on GE-Fanuc plc, & i want to configure it with the AutoLink software, that...
2,053
