Need Mitsubishi FSos RPM Program
RMH
Guest
R
I need a program for a FXos to count RPM....such as using X0 as an input from a prox switch counting pulses and converting them to a "RPM" count so if the count is > xxx then turn on Mxx and < xxx turn on Mxxx.
RMH, this is not a smash and grab site. Nobody will supply you with the logic without seeing what you have done so far.
We are here to help you - but not to do it for you.
First hint though:
If the pulses are very fast, you will need a high speed counter. X0 can be used for a dedicated HSC input.
But, the trick with mitsi is, if you use X0 as a HSC input, X0 does not appear in your ladder logic.
The high speed counters start at C235 so to count high speed pulses at X0, the line would look like this
--| M8000 |--------------------------------(C235)-
Where M8000 is the 'always on bit' Any pulses at X0 will now accumulate in C235
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,592
Hi, Complete novice on PLCs and need your help (again). On GT Designer3 what sort of button/switch do I need to add to Start/Stop a water pump...
1,988
Hi, Can someone help me out? Please excuse my terminology because I'm a complete newcomer to PLCs. The PLC at work is modular/expandable and...
18
4,070
Hello I am new in Mitsubishi PLC's so I have a request to convert a program which is running in a Q06H CPU to the same machine but running a...
2,001
Hello, I have an old machine I'm trying to get reloaded for a customer, and it has a FX2N PLC in it. I have a copy of GX Works FX, but the...
1,765
