Need suggestions for inspecting teak wood.
nandman
Jan 2017
Montreal
I was trying to inspect teak wood (This one is imported, don't know the exact origin). But it seems that the wood is absorbing Penetrants, Is their any way to inspect the wood using penetrant inspection method?
regards
NM
I didn't think you could use the penetrant method on anything that was porous. For the reasons you are having issues currently (it absorbs the penetrant).
I've never tried using a penetrant inspection method in a production capacity. It's always been just one off tests on the bench type thing. So I can offer little in terms of solutions.
Just for my own curiosity, which issue does the absorption cause?
When the material absorbs the penetrant, can you no longer see the defect areas, because the penetrant is gone?
Or
When the material absorbs the penetrant, do areas that are not defective show up as defect due to the presence of the absorbed penetrant?
Or maybe it's just a combination of both?
Hello Everyone, I am reaching out to this knowledgeable community with a peculiar problem I've been experiencing with a PLC 5/40E. This issue has...
2,331
Hi all. I am writing a program in RS Logix 5000. I have 8 pieces of support equipment that are exactly the same. They supply high pressure water...
1,791
Hi All, I have Multiple Galaxies in a Production Plant. We are working to bring in all the HMI controls into a Centralized Control Room. This...
3,208
I have a new project and I cannot use my standard PLCs from Automation Direct as none have a CSA certification. I'm trying to keep costs for...
1,907
Hi there guys, I have been playing with demo of Ignition SCADA and have it reading and writing happily with my S7-1200. The trouble is my boss...
6,145
