NetLink communication to CPU
Mars
Oct 2014
Copenhagen
17
Hi
I wonder about som technical aspect regarding netlink communication to CPU 314-2C DP.
When i set my adress 0 in PG/PC interface (the same as MPI adress in netlink) i can connect to the CPU without problems.
But when i want to connect to CPU from Win CC RT on my computer my MPI adress could change automatically in set PG/PC interface to the same MPI adress as my HMI panel that are connected to the CPU in field.
How could i fix this?
Hello, I have the NETlink USB compact. It works perfectly fine when i use it on a Siemens 300 PLC. But it won’t work with the Beckhoff 315 PLC. I...
2,112
Hi All, I'm using NETLink PRO Compact by HelmHolz to connect a PLC Simens s7-300 and it works good. This means I can go online on to the plc and...
3,845
Hello all can any one tell me what is the difference between 1.cp 5512 vs netlink pro? 2. Which is more superior? 3. How netlink differ...
3,576
hello problem on Netlink Pro Eth. i connected the Netlink to Switch and from there to 2 PCs. i am able to get the data on 2 PCs. Now wants...
2,446
I bought the netlink adapter MPI-LAN from Hilscher. This together with the KepServerEx for Siemens. I can configurate the KepServer, i can put an...
5,490
