New Ethernet module in RsLogix 5000
tjntjntjn
May 2012
USA
93
Hi everyone,
I'm trying to add PowerFlex 525 as a new Ethernet device/module in RSLogix 5000 but this drive is not available in the devices list/catalog. I tried to install EDS file for this drive and installation went OK but the drive still doesn't exist. I'm using RSLogix version 20.01 with Controller 1769-L16ER-BB1B.
I tried the same thing in Studio 5000 version 21.03 but when I right click to add new module I get error "Failed to create module. Class not registered"
What am I doing wrong?
Thank for your help
It's not the EDS file you need in RSLogix 5000.
You need to get the Add On Profile (AOP) for the PowerFlex 525 drives...
544985 - PowerFlex 525 drive: Add on Profile (AOP)
Access Level: Everyone
If you are getting a "Failed to create module. Class not registered" while trying to add the drive in Studio 5000 v21, under Windows 7 64-bit, then see here...
583565 - Studio 5000: Failed to create project Library not registered
Access Level: TechConnect
It's basically a reinstall situation. Corrupted module profiles are a known anomaly.
Regards,
George
Regards,
George
Working on it now. Thanks
​Hello everyone, I triyng to link a Power Module eMB-60R from Robot Adept Viper s650 to CompactLogix, version 19.11 I followed exactly the...
2,698
Does anyone know the comm format, Assembly Instance and Input/Output size for a Rinstrum C500. It appears their EDS file does not work for RSlogix...
1,617
I am trying to add a generic Ethernet module to RSLogix and keep getting an invalid size error. There are no inputs, only outputs. I am using...
5,640
Hi, I have am working on a project to automate a mine site. There are a number of PLCs with EN2Ts, EN2TRs and ENBTs. I am trying to write an AOI...
2,918
I'm trying to connect a Beckhoff Controller to a Rockwell Controller (I'll get more specific in a little bit) so that the Beckhoff is the master...
10,255
