New H&P article about feed forwards
Good article Peter. You make it sound easy!
There are still about 500-1000 analog PI controllers that are installed each year in the US that don't have feed forwards.
Wonder how many of these have at least 6 foot of hose between the valve and cylinder?
Thanks.
I got a call yesterday from someone that makes marine racing engines for hydroplaces and cigarette boats. He will use this feed forward info to make his dynamometer better. This will allow him to optimize the torque and horse power curves.
Who da thunk it! I talked to him for an hour exchanging information. I learned about dynamometers and he learned about how feed forwards can be applied to dynamometers.
I've been thinking over this article for a while, having been meaning to find out exactly what feed forward is for a while.
So, if I put it in simple terms, Feed Forward is the same as an open loop control scheme, only the output of the Feed Forward is summed with a PID controller.
Feed forward sets the output to close to what is desired, feedback corrects whatever minor errors are there.
Have I got it?
I have submitted this tread to a magazine and it got rejected by the editor that obviously has never done motion or used cam tables.
2,146
Does anyone know of a remote particle sensor with an ethernet output that also has a corresponding module to install for bringing the data into a...
1,826
I found this article in today's news interesting ... as if we don't already have enough to worry about these days ... headline: here's a link...
2,414
Hi I downloaded a trial version of Tia Portal and very eager to create offline projects. The problem is ,when choose 'create new project '...
1,454
Hello everyone, I am interfacing AB PLC with a particle counter SC200 using RS Logix 5000. The particle counter value on its screen and the value...
1,676
