new job and I am rusty
jimcav
Dec 2004
new jersey
229
I have 5 production lines and one piece of portable equipment. the portable device needs to move to each production line from time to time, every thing is using control logix. I only have 1 input left on the portable machine. I was thinking of setting up a repeat cycle timer on the production lines each with a different timing cycle. when the portable machine is connected to the production line it would it would identify the timing cycle for the machine that it is connected to. Need some help with the ladder.
Jim Cav
Have each of the fixed machines turn on an output for a different period of time. The input on the portable machine will connect to that output.
In the portable machine use a one-shot from the off-to-on transition of the input to start a timer. Use a one-shot from the on-to-off transition of the input to capture the timer's accumulated value and reset it. Use comparison instructions with the captured value to determine which machine the portable machine is connected to.
Also use the input signal to increment a counter instruction and wait until the counter has an accumulated value greater than 1 before timing the input signal to ensure that you're not timing a partial cycle of the input signal. Reset the counter when you first connect the portable machine.
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
160
Years ago, when I was an Automation engineer, I relied on this site heavily, for help, with questions I had. Many times, this site saved my...
167
HI all, I have a backup from a Series 7000 Cognex camera. I am trying to restore and see the vision tools used in the job. Can I restore those...
72
hello i'm not good at english, please understand i just found this website from googling, while i was looking for how to use program(from m340)...
535
Hi All, I have a programming background but have never used a PLC. I have what I think is a simple automation project however Im not sure of the...
19
1,859
