Newbie question
rickd63
May 2014
Houston
I'm new to this board and learning a lot going through the threads.
I currently have a Micrologix 1100/B and my understanding this does have Modbus/TCP capabilities. I have a network security appliance that will detect (control/register) changes to a PLC device through Modbus/TCP. I'd like to build a lab that can demonstrate changes on my PLC with the network security appliance sitting inline. Is there a way to do this. I'm thinking if there was a way to build a proxy device that will capture the changes and push them out to the 1100.
Hopefully I'm making sense?
/rick
I don't believe the ML1100 supports Modbus TCP. It does however support
Modbus RTU master/slave on its serial port.
The ML1400 does support Modbus TCP on its Ethernet port.
Typo, I meant it does NOT have Modbus/TCP. Any helpful suggestions on a workaround? I don't have the resources to build a lab with a 1400 and the cost of the software.
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,432
Hello. New to Unity and had a couple quick questions. Can a Modicon M340 output to a small multiline LCD screen and not a full HMI?
974
Hi. I'm learning AOI programming in RSLogix 5000. I created an AOI with several input and output parameters but when I choose the AOI in the main...
17
3,325
Good morning, I've had an inverter fail with firmware revision 5.002, the only spare is Rev 7.001, when updating the project with the new...
1,268
Oh, I hope someone can help! I have one little problem holding me up from studying this weekend. I'm using Rslogix micro starter light, it's a...
3,012
