NIM Module
fids
Jun 2002
manila
22
We have a SLC 5/04 with a NIM module installed on its chasis. the nim module is connected to a meter. does anyone knows what is the function of the NIM module and how to configure it. thanks
NI designates it as analog input, the M I assume is for meter since it is connected to one so I am "guessing" its a single channel analog input module with meter. I have not been able to locate anything that says NIM.
Can you get the full part number for the module? May require pulling the card out and looking on side of it.
In many applications "NIM" stands for Network Interface Module.
With out further information, no one is going to be able to answer you question. What is the make and model number of the NIM?
Can't remember right now, but Prosoft may call thier Modbus cards "NIMs".
If it's a PROSOFT or Spectrum Controls module, it's old as that P/N is not listed by either manufacturer. AB doesn't list it either; is it possilble that it is an NI4?
I am working with a Siemens 545 PLC and the MODNIM Modbus module and I am trying to figure out if the module is a Master or Slave. It does Modbus...
1,813
Hey guys! So my question is this, say you are using an integer instead of just an on/off bit for the visibility expression, how would it look...
1,606
I'm trying to connect to a SyMax Processor 300 via a Network Interface Module. I set the communication settings using the dip switches on the...
2,846
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
229
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
116
