No connection Siemens 1200 & MTP1500 Comfort
swedeleaner
Dec 2013
Göteborg
157
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc.
attaching from settings. Have i missed anything? Both plc and hmi responds to ping. Just checked IP-adressses and they should be fine. Is there something to do with profinet name?
Profinet name must be set along with the IP. Topology is optional and can cause a headache if it's not connected exactly as specified.
Are you connected to any other network? 192.168.0.1 is a default IP address and there's a very good chance that something else will be set to that address.
Is there an access password set on the PLC too? There isn't a password by default so there won't be unless you've set it up.
Disclaimer, no real experience with the unified panels. I have only picked up a bit of info here and there.
I TLS security activated ? It is activated by default, and it is AFAIK not trivial to get going.
I think that a security certificate is automatically generated and downloaded to the panel, so in theory it should be transparent to the end-user.
One stumbling stone is that the certificate has an expiration date, and it requires that the clocks are syncronized.
It is possible to deactivate TLS completely.
When the panel starts up, are there any system messages ?
As mentioned, time and date is important, so set it for both HMI and PLC.
Also, make sure you are in the correct ethernet port.
Hello, I'm trying to configure Profibus communications between a CPU1214c by module cm1243-5 and a Parker 590 DC drive. in tia poral software, hex...
1,143
So I have finally had to bite the bullet and do some modifications to some Siemens PLC code written in TIA. I have got both V10.5 and V11...
4,778
259
Hi, I have a plant where we recently changed CPUs from 315-2DP to 315 -2PN/DP. They are all connected to a Beijer panel. Strange thing is that...
1,252
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,621
