No connection to Mitsubishi Aj72-R25
Rosc
Apr 2003
Eindhoven
Hey Guy'sI'm trying to communicate with an oldy.
It's an Mitsubishi Aj72.
I tried to get some info from the net, but there is not allot to be found.
I still think it's just a plc with a coomunication card in it.
But if i start up the software i can't find it back, i don't know to which family it belongs. A,AnN,A2, etc.
I've got the cable, SC-09, it's new and not self made.
I'm using Melsec Medoc plus.
I've also tried earlier versions, but no sucses.
The display says that the plc is running.
But if i try to upload the program, i get a no match.
Can i anyone help me.
This is what i found on the AJ72
If its what you have then its a RIO module for the Q series and not directly a plc itself ?
edit: heres another link showing the AJ72R25 as a data link module for Q series or maybe AnS series, discontinued 2006 ?
Aj72r15
Thanks Dave,
I aspected something like that.
But is it possible to use it as a plc to.
Because it has a communication portr.
Or is that just to say with which plc it has to communicate???
If I'm right the AJ is a communications link to other peripherals, it is an inteligent card for communications you still need a plc module in the rack something like an A1 or A2n etc.
The new Q series have simular cards but you will allways need the PLC card, PSU & Rack.
Hello, As a newbie to PLCs, I have two issues. 1) I connected Mitsubishi GX Works3 and Factory IO on a project I am working on. But when I do a...
1,896
Hi everyone, I am having a hard time trying to get a connection between this two devices. I am already lost on what went wrong. Please help me~~~...
859
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,244
I am trying to connect a Kinco HMI (T070) with the PLC of Mitsubishi (fx1s) but I want to know how can I add PLC tags to HMI Buttons (when I will...
2,973
Hi everyone! I am new on PLC. I bought a plc which name is FX3U 32MT. I need to connect to ASDA B series servo driver. I need to work servo motor...
2,083
