No Mitsubishi Pulse Output
Heald33
Mar 2012
Indiana
I am kinda new to GX Developer. I am trying to fix a pick and place machine that has a FXon-40MR on it. There are rungs that only have one input, X000, and have a pulse as an output, [PLS M0]. When I press the button or trigger the specified input, the input contacts highlight, but the output never does. If there are a set of N.O. contacts that reference a pulsed output, they never hilight either. I can't even get them to force on. Any thoughts?
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,259
I tried to read the actual pulse in D8140. Its shows the current pulse value. but want to compare that pulse for to start motor. for example:i...
2,186
Hey, i wanna use SM1032 on a Mitsubishi Q-CPU but it doesnt switch on/off when i use it, do i need to eneble that function first? Thanks,
11,090
Situation: We have a new machine that has a Mits FX2N Plc and a MRJ2S servo amp and a FX-1PG "pulse generating module". Servo motor is geared...
4,246
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
52
