#ANotJstMenEngr
Well i have found myself in a purely ladder programming environment at new engineering company. I have done troubleshooting and of course it was the first plc interface I learned....oh that was long ago and so many updates and legacy put to rest. Here's my problem: need to store several analog values (Temperatures, gallons, weights, speeds and positions in degrees) then handle calculations, comparisons, and assignments for use in both HMI and PLC. Normally would create FBs and call it when needed to pass values into DBs. I'm sure that is exactly what is happening as well in ladder but darn if i can get easier way that doesn't require 30 to 40 rungs of multiple elements on each rung. Any thoughts on smaller subroutines? I will understand if 30 to 40 (or more) rungs is SOP.
Thanks in advance
Thanks in advance
