No quite PLC talk: Re:Formula for LCD Screen Size?
Aug 2003
71
Gentleman:
Does anyone knows the formula for determining the width and the height dimensions of an LCD Flat screen computer monitor provided you know the Diagonal and the Aspect Ratio dimensions?
Example:
21.3” LCD Screen
With an Aspect Ratio of 16:9
What are the width and the height dimensions?
Thanks all
A matter of angles
Like the link above will lead you to, a right triangle with a hypotenuse of 21.3" will have a opposite and adjacent side with a 90 deg. angle at the intersection of the opposite and adjacent sides. There are two remaining angles in the shape and one can be 60 and the other 30 or both be 45 degrees and still add up to the required 180 degrees for the total angles. The 60/30/90 triangle produces a rectangle when doubled and the 45/45/90 produce a square when the area is doubled. Now, most monitors have rectangle shape so the rest is just a matter of algebra. Easiest way to explain aspect ratio is to say that it means the ratio between the width of the picture and the height of the picture.
The aspect ratio of 16:9 (1.78) is equal to the tangent of the angle opposite the longer side. The inverse of the aspect ratio (9:16 = .5625) is equal to the tangent of the angle opposite the shorter side.
If you know the tangent of an angle, you can calculate the angle. Once you know the angle, you can calculate its sine or its cosine. The length of the side opposite an angle is equal to the hypotenuse times the sine. The length of the side adjacent to an an angle is equal to the hypotenuse times the cosine.
SOHCAHTOA - I resesrve my comments about engineers .
Either didn't go to school in PR or were to smashed for simple maths. Either way - WAKE UP.
Fred
Dont know if I am an engineer BUT the Navy taught me
S suzy
C can
T tell
O oscar
H has
A a
H ha**
O o*
A always
Does yours have a ditty that everyone ALWAYS remembers ??
Dan Bentler
Ah - but this is also easily solvable without resorting to trigonometry with all the SOHCAHTOA stuff. The diagonal and aspect ratio is enough. Want me to show the math?
Pythagoras does indeed rule
16 * X = Long Side
9 * X = Short Side
21.3 = Hypotenuse
Square Root( Long Side ^2 + Short Side ^2) = Hypotenuse
Square Root( (16 * X)^2 + (9 * X)^2)) = 21.3
Square Root( (256 * X^2) + (81 * X^2)) = 21.3
Square Root( (337 * X^2) ) = 21.3
Square Root(337) * X = 21.3
18.3575 * X = 21.3
X = 21.3 / 18.3575
X = 1.16028
(Oops, should have checked again before I posted. Peter beat me.)
16 * 1.16028 = 18.5646 = Long Side
9 * 1.16028 = 10.4426 = Short Side
Well, at least I am impressed!
You guys are good. Just goes to show the depth of knowledge we are fortunate to have access to here on PLCs.net. :site:
Anybody knows any web explaining DCS just like "Learn PLC" site??
24
I'm from a Mitsubishi Q-series background so excuse my ignorance. In Mitsubishi world, in my experience your Mbits (booleans) are just M1, M2...
20
2,808
We went to see the Hamilton show. The lights moved and changed colors and props magically moved across the stage. I've seen posts here from...
2,975
From the IT world but generic enough to apply to PLC programming as well...
3,768
This is what I got from ABB Control Builder Help file about RS flip flop: How to Use the Function Block The RS bistable flip-flop, is a latch...
6,671
