Non-PlC related, but looking for help
Agian, thank you. i will be trying the Connmac. will also report on how they worked after we trial for some time.
rgds
Don't suppose this is the answer your looking for, but...
I too used to work in a meat processing plant, with an 8 hour night shift power hosing everthing.
After many painful months of trying to prevent water ingress to connectors, sockets, light switches (they used to turn these on and off with the 110bar pressure washers to save un-gloving their hands!), we found the most effective solution was to re-train the washing operatives and then enforce a strict disciplinary procedure for any damage caused.
Probably not legal but it reduced "drying out times" by 50% each morning!
I put in a control system in a turn-of-the-century caustic soda plant (19th -> 20th!) in the mid 1970s. The atmosphere there was so bad that after about 20 minutes your skin was stinging like mad - I hate to think what it was doing to my lungs!
We had loads of problems with keyboards and switch contacts, but over about 15 years, not once did we have a problem with the plant cable connections which used the Amphenol Mil-Spec connectors mentioned by Ron.
SLaubach,
A company I work for manufactures a re-enterable encapsulate that is used in splice enclosures for the telecommunications industry. It is supposed to be completely water proof but yet crumbles away easily when you need to remove it. Email my at [email protected] and I can get you in touch with some one if you are interested.
Hello All, It's past that time where my membership ran out, so I've come to do a Lifetime upgrade this time... but it won't let me. It keeps...
2,448
Hi guys- sorry this isnt PLC related but i know there is a lot of guys here that could answer this with all their electrical knowledge. The...
17
13,925
I am looking for some help with a project that I am working on to finish my maintenance apprenticeship. Any help would be greatly appreciated. My...
3,352
What he have is a HMI2GO unit ( KTP900F) and we use a safety relay to trigger our e-stops. What the tech wants to do is guard against e-Stop on...
1,882
(Allen Bradley PLC)Issue resolved by download the project, But What is the main root cause of this Major Fault Error code 62 “Non-Recoverable...
3,276
