Noob Siemens Question about time set outputs.
Big_Robo
Nov 2016
England
81
Hi, I have tried everything but still having no luck. This will be a easy solution I just know it.
Ok I want to be able to set off an output when the time of day hits e.g. 7.30am and off again at 2.30pm
How the hell do I do this in ladder.
Thank you.
Sorry its in Tia Portal v15
In Step7, I believe you can fire off an OB at a set time... so as long as you don't have to change that you can run two OB's and just set/reset that output.
TIA Portal should allow the same... however, this isn't a fantastic way to do it.
This is probably what you want:
https://support.industry.siemens.co...ls-for-date-and-time-functions?dti=0&lc=en-WW
https://support.industry.siemens.co...ing-the-data-types-dt-and-dtl-?dti=0&lc=en-WW
https://support.industry.siemens.co...-and-time-for-the-cpu-modules-?dti=0&lc=en-WW
Thank you, will take a read, this should be easier to do than it is .
Hi. I've artfully avoided Siemens for a whole decade but now it's inescapable. I'm trying to figure out what software is needed to support new-ish...
6,386
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
964
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,267
I need to be able to open a customer's FT View project and make any changes if necessary. Which one do I need??? :hmmm: I don't want to have...
2,594
Hello all, i will start off by saying i know nothing about load cells, i want a converter/amplifier to output a 4/20mA signal from a load cell...
5,409
