Not able to expose RSView control to VBA
pequeajim
Jul 2009
New Holland, PA
I have a CPR7 RSView application that I can not expose a string input control to VBA so that I can write the value to a .csv file. Here is what I know at this point.
I have RS View SE Stand Alone loaded in two places, one for production and the other an a VM for working on the app at home.
The OS is the same on the production box and the VM; XP, SP2
If I try to expose the string input as a VBA control on the Production box, RSV does not allow me to do so.
If I backup the app and restore it on the VM and do the same, it works.
I also tried creating a new app and new screen with just the string input object, exposing it to VBA did not work on the new app.
I tried opening an existing app and dropping a string input object on a new screen to do the same and this did not work.
I tried uninstalling RSView and reinstalling it and this also did not work.
I searched through the Knowledge base on Rockwell's site and could not find anything relating to this.
The only thing I can add is that when I unstalled and reinstalled RSView , the applications were not removed. Could this have an effect?
The license key is installed and I can talk to the I/O
I can't think of anything else, so any suggestions would be greatly appreciated.
Jim!
70
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
121
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
270
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
366
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
138
