Novice: HMI connected to Industrial PC
LiamD
Feb 2012
UK
I have no experience of HMI/PLCs, I am more of a micro controller programmer.
I have been tasked to connect a Mitsubishi GOT1000 HMI to an industrial PC over a serial connection RS232/RS422. I would be using the GT Designer software.
From my understanding the standard protocol for HMI communication relies on communication with a pre-define PLC. The registers content within the PLC can be easily displayed on the HMI. Connecting to a PLC to HMI is fairly simple.
Now for my case (between HMI and Industrial PC) can anyone give guidance on the feasibility for me to read data from the PC and display on the HMI. Do I have to define the serial messages or are these predefined? Or can I add a driver to the PC to act like a PLC for the serial communication?
Any guidance appreciated.
Thanks,
Liam
I am not familiar with your HMI, but I would suspect that if you can get the PC to speak Modbus you may be able to get something to work, or if you can use DDE/OPC connections.
Both of these options would require that the HMI supports them too.
Hi, first time poster just wondering if anyone has any tips for a novice of the PLC world, I've worked with them a fair bit within schooling and...
3,264
We're a used machinery merchant and have a Siemens PLC that has lost its program due to a dead battery. We have the software to download but, at...
22
6,640
Hi I’ve got a door and window switch from RS (190-1011) with a 4 core cabl - red, white, green, and yellow . The red and white are the switch and...
1,360
I'm self taught so far, so hang with me as I try to explain my issue. I've got an archived program file for a PVP6 that I'm opening on FT ME ver...
2,598
If 95% of our PLCs are AB (micro 1500, slc5/03,04 make up the bulk) what would be the language to learn to use scripting? Also to move towards...
2,166
