NPN and PNP
Timeismoney08
Jul 2012
United States
312
Can anyone explain the difference in NPN and PNP in a short answer?
i have watched many videos and read articles but i still dont understand completely, and how it has to do with on photo-eyes
The ab guys will hate my explanation...
Think of pnp as current sourcing. You can drive a small micro relay from a photo eye. Connect the a1 to the photo eye output and connect the a2 to your 0v. So it provides the power (current sources).
Think of npn as current sinking. From your new npn photoeye you connect the output of the photo eye to the a2 of your relay an connect the a1 to the 24v. So it provides the path to 0v (current sinks).
Be careful as different manufacturers describe this different ways - AB for example.
I look at PNP as positive switching and NPN as zero switching (or near to zero). From my experience that is the most common explanation but read above.
Forget the terms sinking and sourcing. They have been butchered to the point of being arbitrary.
Maybe an easier way to look at it as Bob mentions
N for Negative Logic and P for Positive logic.
The key is to look at what the field device gives you in the ON state. Think of it as a wall switch in your house.
An NPN wall switch would give you common (connects you to white)
A PNP wall switch would give you HOT (connects you to the black)
In either case, when the switch is off you have no current path.
So the in the NPN analogy of wiring a 115vac light bulb, you would bring 115vac to the bulb all the time, and switch it the common.
With the PNP analogy, it would be just like it is normally done. Common is brought to the bulb all the time, and you switch 115vac to it instead.
Applying the same reasoning to a DC photoeye
NPN ON:0V
NPN OFF: N/C
PNP ON: +V
PNP OFF: N/C
If I may digress; I can picture a poor apprentice (me 8 years ago) with a dark on NPN photoeye whilst detecting an object. 22.4VDC on the output it must be PNP, i'll get one overnighted from somewhere! Darn, why doesn't that new sensor work! **** it was NPN. Dark on Light on WTF? lol good times.
be careful as different manufacturers describe this different ways - ab for example.
I look at pnp as positive switching and npn as zero switching (or near to zero). From my experience that is the most common explanation but read above.
+1
+1
+2
Exactly the way I think of it. "Sink" and "Source" are virtually meaningless any more, especially if you deal with multiple manufacturers' products.
BTDT. Well, almost. Trying to figure out why an input wasn't behaving the way I thought it should. It had 24V on the input terminal, but it was off. The "load" wire on the sensor also had 24V. Of course, I finally (after a VERY long time) noticed the big letters on the front of the SLC input module, "SOURCING", and realized that something was up. First time I had so much as heard of such a thing and it was late at night with a "hot" machine down. Only machine in the building with that arrangement. Remember it like it was yesterday. Lessons learned the hard way tend to stick around a while.
NPN and PNP refer to two types of transistors - the way the silicon wafers are arranged creates the two different types. Both types are bipolar-junction transistors. The N silicon layers are positively doped and the P layers are negatively doped.
NPN: is a bipolar junction transistor in which a P-type semiconductor is sandwitched between two N-type semiconductors. The electron current-flow is from the transistor Emitter to Collector (via Base in common- base transistor). Used as a Source, the NPN Emitter will be positive.
PNP: is a transistor in which the N layer is sandwiched between the two layers of P-type semiconductor. The anti-electron current flow is of electron "holes" from Emitter to Collector (via Base in case of common base transistor). Thus the PNP current flow is negative with respect to the positive NPN current flow. Used as a Source, the PNP Emitter will be negative.
All other references to NPN and PNP are loosely based on the transistor types used. Some PLC manufactureres try to define their PLC inputs and outputs in terms of the type of transistor used, but to be meaninful, the location of the transistor (Source or Load) must be specified.
yea when we get to talking about the internal workings is when i get lost. I've found this picture to help me the most.
but I thought it was bad to have a switch on the 0v side of the load
and I've only seen pnp/npn on proximity switches and photo eyes, guess i never noticed on an wall outlet.
Notice that this is really not about "NPN and PNP". Those are properly transistor types. What you are talking about are types of Sources and Loads. A Source does not have to be a transistor, and a Load does not have to be a transistor.
If you start thinking that the transistor type translates as the Source or Load type, then when you encounter a transformer Source or a relay Load, you are going to be screwed.
many people do ...
many people do ...
many people would agree with you – because if the "switch side" of the load gets "grounded" somehow (by a chafed wire, etc.) then the load would be energized ...
but ...
in DC sensor circuits, finding the "switch" (the sensor) on the 0v side of the load is a very common occurrence ... for better or for worse, many DC sensor circuits are wired that way ...
I'm losing you on that one ... when we talk about NPN and PNP we're NOT talking about wall receptacles, etc. ... the posts that I linked to are ONLY concerned with DC circuits (like sensors and photo eyes) – NOT with AC wall receptacles, etc. ...
Hi to All, How I can change NPN to PNP solid state switch? Exapmle1: D-M9N Solid state switch with D-M9P Exapmle2: or allen bradley p.e.c. type...
1,437
Hello; I have noticed one thing more that some time OEM selected NPN PLC I/Os instead of PNP while with PNP the trouble shooting is easy. This...
3,566
I moved my Shopbot and the only problem that I had was a broken proximity sensor. I found a replacement sensor...
1,788
hello,any body can design pnp to npn converter to use plc ,you know plc's work with 4 to 20 mA and 0 to 48 DC volt or 0 to 120 AC voltage...
1,655
