Number of I/O Calculation
Waseem1234
Apr 2018
Lahore
Hi
I am beginer of Allen Bradley PLC.
Is there any one who can answer that how we can calculate the number of I/O's that a PLC can handle?
(I know it is written in Data Sheet of a particular controller, but how that number is calculated, is a question.)
Thank you very much!
Not really quite sure why you would want to calculate it versus read the manual ?
Either way i doubt there will be a calculation published anywhere for this, it's not the sort of metric that's calculated other than by the manufacturer based on numerous reasons (power supply budgets, physical sizes, software, OS, firmware etc. etc.)
Analog outputs tend to be DC power higs and they dissipate a lot of heat, so the number of AO’s is frequently limited due to heat dissipation and available DC power. But that’s a spec by the manufacturer. A power consumption calculation is provided so one stays within limits.
Hi
Check the manual, develop a spreadsheet for quick checking.
If you can get your distributor to set you up with IAB (Integrated Architecture Builder) it has some tools for building a large system and their Ethernet tool will tell you if your going to be able to get the scan times you want.
All well and good if using Allen-Bradley, but not specified by the OP.....
Welcome to the forum.
as with any plc, the manufacturer has tested the plc to see how many I/o the cpu can handle and in what configuration(s). it would be wreckless of them to sell a plc system without knowing what its limitations were.
I recommend that you look in the user manual for various I/o configurations that can be used. if you exceed that limit, look for a larger capacity plc.
regards,
james
Hello guys! It's been a while since last time I posted here. I haven't been working with plc's for a while but no I'm up to my ears... I like...
25
7,489
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
123
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,096
Hi, I have this weird issue whenever I try to change the SNN from a Point IO Im missing the three ... dots to open the pop up and change it...
622
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst. One thing I don't find is a way...
706
