Numeric input enable properties
knucklebucket
Feb 2013
Greeneville, Tennessee
54
Factory Talk question of the day, can a numeric input enable be reset to 0 after a batch cycle complete? I don't see anything in the properties window that would allow that?
the desired outcome would be I touch a numeric input, my window pops up, I input number, batch cycle starts and when load weight is achieved and cycle completes, it would automatically reset my target to 0.
Is it connected to a PLC tag? If so clear the PLC tag. Is Continuously Update checked?
it is writing to a PLC tag, is does update, but I need to determine how to write back to the numeric input from the PLC
I did some slurry dispenser machines and I had to do this. There are other ways, I'm sure, but I assigned a tag in logix as an example "Recipe preset" and made that a connection to the numerical keypad in the HMI. Then I would use a MOV block in logic to move "Recipe Preset" value to a tag called "Current_Recipe" for instance, and connect "Current_Recipe" to a numerical indicator in the HMI. After "Cycle_Complete" I would activate a "CLR" instruction with a one-shot and the tag for the "CLR" instruction in logic would be "Recipe Preset". This would then move a zero into the numerical indicator in the HMI after the cycle completed. Hope this helps.
thanks I will give that a try
Tom
I'm working on converting an old PanelBuilder 1200 HMI application into FactoryTalk View ME. The PLC was an old SLC 5/02 with a scanner card for...
1,109
I'm using numeric input enable link tag to PLC DINT type. What I want is for the example in the panel view user will input 350.568 (and shown on...
1,170
I'm trying to use a Numeric input enable to let users change their HMI password. The only problem is it deletes leading zeros when you enter it. I...
1,932
Good Afternoon , I have an older Panelview Plus and do not have the application . I'm in the process of re-doing the HMI application from...
3,918
Good Morning , I'm trying to use a Numeric Input Enable in a FactoryTalk ME application. I have a REAL ( Data Type ) that I would like to...
7,190
