Kataeb Member K Join Date Jan 2007 Location www.livelovelebanon.com Posts 636 Mar 28, 2019 #1 We have an OB80 error B#16#01 Cycle time exceeded , on a cpu 315 . What could be the solution ? See attached . Thanks
gclshortt Member Join Date Dec 2014 Location Ontario Posts 3,217 Mar 28, 2019 #2 http://www.plctalk.net/qanda/showthread.php?t=75320 The above thread may help you out. Regards,
sigmadelta Member S Join Date Apr 2016 Location From Canada - Living in Bulgaria Posts 2,010 Mar 28, 2019 #3 Open the Module Information (same place where the Diagnostic Buffer is), and look at the B Stack, and click Open Block. This shows the exact location where the program stopped, and it may be the location that is causing you problems.
mk42 Lifetime Supporting Member M Join Date Jun 2013 Location MI Posts 3,301 Mar 28, 2019 #4 What changed to have that happen? Were you online? Had you just downloaded new code? What is your typical cycle time? What is your max cycle time?
